Steel Muscle in New Vehicles----Hyundai Sonata
   date:2020-05-09     Source:worldautosteel       [ 进入汽车材料社区 ] [ 汽车材料馆 ]
Abstract:2020 Sonata Implements a Third-Generation Vehicle Platform Featuring Hot-Stamped SteelNew platform enhances design, safe
  • New platform enhances design, safety, efficiency, power and driving performance
  • New structure dramatically improves collision safety and enables innovative design elements
  • Hyundai will expand implementation of the new platform to future vehicle products
汽车用钢
Hyundai Motor announced that it has implemented its third-generation vehicle platform to the new generation Sonata. The new generation Sonata offers reduced weight and improved fuel efficiency while also achieving stronger durability with the new platform. The platform builds on the former platform’s core advantages, enabling a stable design with a lower center of gravity. The third-generation platform also allows Hyundai to implement sporty and stylish design elements to the new Sonata.
Sonata's 3rd Generation Body Structure
Sonata’s 3rd Generation Body Structure boasts Hot-Stamped Steels for improved performance
The platform also delivers a significant improvement in collision safety through the adoption of a multi-load path structure, ‘Hot Stamping,’ and Advanced High-Strength Steel.
The sophisticated multi-load path structure increases the energy absorbed by the vehicle in a collision, improving safety with minimization of collision impact into the passenger cabin, thereby improving vehicle safety.
The platform is designed so that the tires move outward during a small overlap collision to maximize customer safety. Such technology inhibits the vehicle from spinning and prevents possible secondary collisions.
Watch this impressive video on Sonata’s structure and performance:
The all-new Sonata equipped with the new platform is also expected to improve power and driving performance. It has been developed for possible application of Hyundai’s next-generation engine called the Smartstream Powertrain.
Featuring a system that controls the flow of air, the new platform improves air movement to the engine bay and heat dissipation, which enhances stability in the lower part of the vehicle and minimizes air resistance to deliver excellent efficiency and power performance.
Stability is enhanced by lowering the position of heavy equipment in the platform, which reduces weight and lowers the center of gravity. In addition, it enables agile handling by dramatically expanding lateral stiffness and positioning the steering closer to the wheel center while also providing stable and balanced driving performance by implementing tire-optimization technology. Noise reduction is also improved with enhanced noise, vibration and harshness (NVH) performance through reinforced sound-absorbing systems in vibration-sensitive parts.
“Through implementation of the third-generation platform, the new generation Sonata is expected to provide world-class value in overall vehicle performance,” said Fayez Abdul Rahman, Vice President, Architecture Group from Hyundai Motor Company. “Starting with the new Sonata model, Hyundai will gradually expand the use of this new platform in order to provide joy of driving and comfort to the customers.”
REWARD
MORE>Similar TopicEnglish
TOP STORIES
EDITOR’S CHOICE English
MOST VIEWED
