Researchers get to know battery particle inside and out
   date:2020-09-16     Source:Materials Today.       [ 进入汽车材料社区 ] [ 汽车材料馆 ]
Abstract:The particles that make up lithium-ion battery electrodes are microscopic but mighty. They determine how much charge the
 The particles that make up lithium-ion battery electrodes are microscopic but mighty. They determine how much charge the battery can store, how fast it charges and discharges, and how it holds up over time – all crucial for high performance in an electric vehicle or electronic device.
(Left) An X-ray microscopy image of particles within a nickel-rich layered oxide battery electrode. (Right) A single charged particle welded to the tip of a tungsten needle; the particle is about the size of a red blood cell. Image: S. Li et al., Nature Communications, 2020.
Cracks and chemical reactions on a particle's surface can degrade performance, and the whole particle's ability to absorb and release lithium ions also changes over time. Scientists have studied both, but until now they had never looked at both the surface and the interior of an individual particle to see how what happens in one affects the other.
In a new study, a research team led by Yijin Liu at the US Department of Energy's SLAC National Accelerator Laboratory did exactly that. They stuck a single battery cathode particle, about the size of a red blood cell, on a needle tip and probed its surface and interior in 3D with two X-ray instruments. This revealed that cracking and chemical changes on the particle's surface varied a lot from place to place and corresponded with areas of microscopic cracking deep inside the particle that sapped its capacity for storing energy.
"Our results show that the surface and the interior of a particle talk to each other, basically," said SLAC lead scientist Yijin Liu, who led the study at the lab's Stanford Synchrotron Radiation Lightsource (SSRL). "Understanding this chemical conversation will help us engineer the whole particle so the battery can cycle faster, for instance." The scientists report their findings in a paper in Nature Communications.
A lithium-ion battery stores and releases energy by moving lithium ions back and forth between two electrodes, the anode and the cathode, separated by an electrolyte. When the battery is charged, lithium ions rush into the anode for storage. When the battery is used, the ions leave the anode and flow into the cathode, generating a flow of electrical current in the process.
Each electrode consists of many microscopic particles, and each particle contains even smaller grains. Their structure and chemistry are key to the battery's performance. As the battery charges and discharges, lithium ions seep in and out of the spaces between the particles' atoms, causing them to swell and shrink.
Over time this can crack and break the particles, reducing their ability to absorb and release ions. Particles can also react with the surrounding electrolyte to form a surface layer that gets in the way of ions entering and leaving. As cracks develop, the electrolyte can penetrate deeper to damage the interior of the electrode.
This study focused on particles made from a nickel-rich layered oxide, which can theoretically store more charge than today's battery materials. It also contains less cobalt, making it cheaper and less ethically problematic, since some cobalt mining involves inhumane conditions, Liu said.
There's just one problem. The particles' capacity for storing charge quickly fades during multiple rounds of high-voltage charging – the type used to fast-charge electric vehicles.
"You have millions of particles in an electrode. Each one is like a rice ball with many grains," Liu said. "They're the building blocks of the battery, and each one is unique, just like every person has different characteristics."
Scientists have been working on two basic approaches for minimizing damage and increasing the performance of particles: covering them with a protective coating, and packing the grains together in different ways to change the internal structure. "Either approach could be effective," Liu said, "but combining them would be even more effective, and that's why we have to address the bigger picture."
Shaofeng Li, a visiting graduate student at SSRL, who will be joining SLAC as a postdoctoral researcher, led X-ray experiments that examined a single needle-mounted cathode particle from a charged battery with two instruments – one scanned the surface, the other probed the interior. based on the results, theorists led by Kejie Zhao, an associate professor at Purdue University, developed a computer model showing how charging would have damaged the particle over a period of 12 minutes and how that damage pattern reflects interactions between the surface and the interior.
"The picture we are getting is that there are variations everywhere in the particle," Liu said. "For instance, certain areas on the surface degrade more than others, and this affects how the interior responds, which in turn makes the surface degrade in a different manner."
Now, he added, the team plans to apply this technique to other electrode materials it has studied in the past, with particular attention to how charging speed affects damage patterns. "You want to be able to charge your electric car in 10 minutes rather than several hours," he said, "so this is an important direction for follow-up studies."
Key words: battery
REWARD
MORE>同类English
TOP STORIES
EDITOR’S CHOICE English
MOST VIEWED
