New approach to recover anode materials from spent Li-ion batteries
   date:2020-11-12     Source:GCC       [ 进入汽车材料社区 ] [ 汽车材料馆 ]
Abstract:A team from Shandong University of Technology in China has proposed a new process to recycle anode materials from spent
 A team from Shandong University of Technology in China has proposed a new process to recycle anode materials from spent lithium-ion batteries and to reuse the graphite.
The graphite and copper foil of the anode are separated by an electrochemical method: copper foil coated graphite is the negative electrode, the inert electrode is the positive electrode, the electrolyte solution is Na2SO4. The graphite thoroughly separates from the copper foil; simultaneously, lithium was dissolved into the solution.
The copper foil can be directly reused without further treatment, the Cu2+ and Li+ in the electrolyte can be recovered by precipitation.
1-s2.0-S0378775320314543-fx1_lrg
The purity of recovered graphite is about 95%, and the graphite can be reused to prepare the anode materials for lithium-ion batteries that exhibit excellent cycling stability and rate capability. The first discharge and charge specific capacities at a rate of 0.1 C are 427.81 mA h g−1 and 350.47 mA h g−1, respectively. The coulombic efficiency after the second cycle is observed to be about 98%.
A paper on the work is published in the Journal of Power Sources.
Resources
  • Ning Cao, Yali Zhang, Linlin Chen, Wei Chu, Yaoguo Huang, Yun Jia, Ming Wang (2020) “An innovative approach to recover anode from spent lithium-ion battery,” Journal of Power Sources, doi: 10.1016/j.jpowsour.2020.229163
Key words: batteries anode materials
REWARD
MORE>同类English
TOP STORIES
EDITOR’S CHOICE English
MOST VIEWED
