The Automotive Carbon Fiber and Its Composites Annual Development Report 2020
   date:2020-03-09     Source:CAM       [ 进入汽车材料社区 ] [ 汽车材料馆 ]
Abstract:《车用碳纤维及其复合材料年度发展报告》2020版正式发布!The Automotive Carbon Fiber and Its Composites Annual Development
The “Automotive Carbon Fiber and Its Composites Annual Development REPort 2020” is Officially Released
      碳纤维复合材料因其优异的机械性能、防腐性、可设计性等表现,一直以来都颇受汽车制造商的青睐。自宝马在其i系列车型成功使用碳纤维复合材料后,行业对于这一“黑色黄金”材料的应用研究也在不断发展。随着国内前途K50和蔚来ES6两款量产碳纤维复合材料部件车型的亮相,让车用碳纤维在自主品牌车型上再一次华丽绽放。与此同时,碳纤维复合材料的应用范围也不断扩展。从车身、内外饰系统向底盘、动力总成系统延伸;从外覆盖件材料向结构件材料或结构增强材料延伸。然而,碳纤维的批量化应用还面临着成本、生产周期、成熟的工艺体系、有效的材料回收工艺等方面的问题。需要在解决材料、设计、回收等技术问题的同时,逐步完善相应技术体系和应用标准的建设,同时还需要建立涵盖碳纤维原丝、树脂、复合材料成型工艺及设备、结构设计、检测与评价、材料回收与再利用等全面的成熟的稳定的产业供应链。这无疑需要全行业产业链的共同努力和进步。
      Carbon fiber composites have always been favored by car manufacturers for their excellent mechanical proPErties, corrosion resistance, designability and other performance. Since BMW successfully used carbon fiber composite materials in its i-series models, the industry's research on the aPPlication of this "black gold" material has also continued to develop. With the appearance of the QIANTU K50 and NIO ES6, both of which have been in mass production, carbon fiber has once again blossomed on its own brand models. At the same time, the scope of application of carbon fiber composite materials is also exPAnding. It extends from the car body, interior and exterior trim systems to the chassis and powertrain system; from the outer cover material to the structural material or structural reinforcement material. However, the batch application of carbon fiber also faces problems in terms of cost, production cycle, mature process system, and effective material rECOvery process. It is necessary to gradually improve the construction of the corresponding technical system and application standards while solving technical problems such as materials, design, and recycling. At the same time, it is also necessary to establish a comprehensive mature and stable industrial sUPply chain covering carbon fiber strands, resins, molding equipment, structural design, testing and evaluation, material recycling and reuse. This undoubtedly requires the joint efforts and progress of the entire industry chain.
  基于此,中国汽车材料网及汽车轻量化在线研究团队通过行业调研,对年度车用碳纤维技术进展、最新应用案例等进行整理,《车用碳纤维及其复合材料年度发展报告》2020版即将发布!在过去一年里,车用碳纤维领域有哪些新技术进展?让我们一起来了解一下吧~
        Therefore, the China Automaterials Website(www.qichecailiao.com) and the Automotive Lightweight Online(www. autolightweight.com) Research Team sorted out the carbon fiber technology progress and the latest application cases through industry research. The “Automotive Carbon Fiber and Its Composites Annual Development Report 2020” will be released soon! What new technological progress has been made in the field of automotive carbon fiber in the past year? Let's find out together ~
  碳纤维材料技术进展/The Technology Progress of Carbon Fiber Material
  AI工具助力结构设计:英国巴斯大学(The University of Bath)采用新型AR工具辅助碳纤维层压板的铺层设计,提升结构成型精准性。
       Structural design with AI tools: The University of Bath, UK uses a new AR tool to assist in the design of carbon fiber laminates to improve the accuracy of structural molding.
  彩色碳纤维部件:日本积水公司Sekisui Chemical通过溅射技术在碳纤维织物表面附着一层超薄离子化金属颗粒层,从而获得彩色碳纤维汽车部件。
  Colored carbon fiber parts: Sekisui Chemical of Japan attached an ultra-thin layer of ionized metal particles to the surface of carbon fiber fabrics by sputtering technology to obtain colored carbon fiber automotive parts.
  碳纤维的低成本化:美国4M Carbon公司专利技术实现碳纤维生产线初始投资减半,其合作西班牙Montefibre公司的超大丝束技术,进一步降低碳纤维前体的成本,期待双方合作的低成本碳纤维技术早日应用推广。
  Low cost of carbon fiber: The patented technology of 4M Carbon Company in the United States halved the initial investment in carbon fiber production lines. Its cooperation with Montefibre's large-tow technology has further reduced the cost of carbon fiber precursors. We look forward to the early application and promotion of low-cost carbon fiber technology in cooperation between the two parties.
  新型木质素碳纤维:GreenLight项目团队采用生物基材料——木质素作为前体,生产碳纤维,同时研究了新型碳纤维的中试规模生产工艺,提升碳纤维的成本效益、绿色和可持续性。
  New Lignin Carbon Fiber: The GreenLight project team uses a bio-based material, lignin, as a precursor to produce carbon fiber. At the same time, the pilot scale production process of new carbon fiber was studied, which improved the cost-effectiveness, greenness and sustainability of carbon fiber.
  超强碳纤维:新孚达(NFD)开发出弯曲刚度超过52GPa、弯曲强度高达520MPa、拉伸强度达到315MPa的超强碳纤维,HEPla® H7200-XCF系列成型零部件可有效实现轻量化。
  Ultra-strong carbon fiber: NFD has developed ultra-strong carbon fiber with a bending stiffness of more than 52GPa, a bending strength of up to 520MPa, and a tensile strength of 315MPa. Hepla® H7200-XCF series molded parts can effectively reduce weight.
  碳纤维复合材料应用进展/Application progress of carbon fiber composites
  ▼碳纤维车顶:马自达在其最新MX-5 Drop-Head CoUPe车型上配置了一款可拆卸的碳纤维硬顶,提升车身结构刚度,为用户提供更为安全的防护。
          Carbon fiber roof: Mazda has a detachable carbon fiber roof on the MX-5 Drop-Head Coupe, which improves the rigidity of the body structure and provides users with more secure protection.
  ▼ 中空碳纤维保险杠:英国公司采用碳纤维增强聚氨酯丙烯酸酯树脂,通过挤拉成型制造了一款中空碳纤维保险杠。
           Hollow carbon fiber bumper: A British company uses a carbon fiber reinforced polyurethane acrylate resin composite material to produce a hollow carbon fiber bumper through extrusion.
  ▼ 可回收碳纤维车门:一汽采用热塑性塑料与碳纤维开发了一款可100%回收的碳纤维塑料车门。
            Recyclable carbon fiber door: FAW has developed a carbon fiber plastic door using thermoplastic and carbon fiber, which is 100% recyclable.
  ▼ 碳纤维悬挂连杆:英国公司采用碳纤维增强环氧树脂开发了一款碳纤维悬架连杆,进一步实现底盘轻量化。
           Carbon fiber link: A British company developed a link using carbon fiber reinforced epoxy resin to reduce the weight of the chassis.
  ▼ 碳纤维补强副车架:赫氏复材采用其开发的HexPly碳纤维预浸料补片技术对铝合金副车架进行补强,改善副车架性能。
           Carbon fiber reinforced subframe: Hexcel Composites uses its developed HexPly carbon fiber prepreg patch technology to reinforce the aluminum alloy subframe, which improves the performance of the subframe.
  ▼ 碳纤维输出轴:德国Dynexa公司采用碳纤维增强塑料开发了一款减震器输出轴,为悬挂系统提供新的轻量化方案。
           Carbon fiber ouTPUt shaft: German Dynexa company developed a shock ABSorber output shaft using carbon fiber reinforced plastic, which provides a new lightweight solution for the suspension system.
  ▼ 碳纤维电池壳:SGL Carbon与蔚来汽车合作开发了碳纤维复合材料电池外壳,实现减重40%。
           Carbon fiber battery case: SGL Carbon cooperated with NIO to develop a carbon fiber composite battery case, which achieved a 40% weight reduction.
  了解更多碳纤维最新进展请关注《车用碳纤维及其复合材料年度发展报告》!
购买完整版报告可长按识别上方二维码进入
To PURchase the full version of the report, press and hold the QR code above to enter
The report is available in English and prices are subject to negotiation
联系人/Contact:张女士/Ms. Zhang
电话/Tel:0551-63857995;17756072694
微信/WeChat:18156085929
附:报告目录大纲
Report Contents
Key words: Carbon Fiber
REWARD
MORE>同类English
