Kingfa supplies UD tapes for Ford door modules
   date:2019-11-04     Source:CompositesWorld       [ 进入汽车材料社区 ] [ 汽车材料馆 ]
Abstract:Kingfa supplies UD tapes for Ford door modules
Kingfa Sci. & Tech. Co. Ltd. and its subsidiary Guangzhou Kingfa Carbon Fiber Materials Development Co. Ltd. (Guangzhou, China) have announced that they are supplying continuous fiber-reinforced materials for the mass production of lightweight door modules in the new Ford Focus.
In the development of a new continuous fiber-reinforced material called KingPly, Kingfa worked closely with the German system supplier Brose Fahrzeugteile (Coburg, Germany). Brose designed the carrier of the lightweight door module with the goal of significantly reducing weight without sacrificing performance. Brose also further increased functional integration. In this case, a weight saving of about 35% was achieved, compared with a carrier made of injection molded material using current technology. In the four-door Ford Focus, this means a reduction in vehicle weight by more than 1 kilogram compared to a door module carrier made of PP-LGF 30.
Door module carrier for the Ford Focus. Source | Kingfa
The material’s thin single layers of unidirectional (UD) tapes, under the brand name KingStrong, can be used to produce customer-specific semi-finished products in the form of plates called KingPly, which are tailored exactly to the application and requirements. In the case of the door module, a very thin but high strength multilayer material was developed, consisting of a polypropylene (PP) matrix with continuous glass fiber reinforcement. The material is said to give the component rigidity and strength.
“The semi-finished products, tailor-made with UD tape assemblies, now enable more efficient components that are even more capable of implementing the concept of lightweight design than the previously known materials of this type based on fabric,” says Martin Klocke, vice general manager automotive business of Kingfa Sci. & Tech. (Europe) GmbH, the European subsidiary based in Wiesbaden, Germany.
“With our newly developed materials, we have demonstrated the innovative strength of Kingfa and hope to be able to support our customers even better than before in their lightweight construction projects,” says Peng Xiao, general manager at Guangzhou Kingfa Carbon Fiber Materials Development.
According to Xiao, Kingfa has been investing in its production facilities over the past several years and is now prepared for large-volume production runs.
Kingfa believes its composite and injection molding materials can provide a solution for many cost-effective lightweight automotive applications.
Kingfa’s portfolio currently consists of UD tapes, chopped glass layers and organic sheets, which are predominantly based on glass fibers and thermoplastic matrices. For KingPly Organo Sheets, PP and PA6 are mainly used in automotive applications, while KingStron PP, PA6, ABS and HDPE UD tapes also offer opportunities outside the automotive sector. In particular, Kingfa sites its mix of organosheets with UD tapes as local reinforcements as a potential future solution for recyclable, affordable lightweight construction.
REWARD
MORE>同类English
TOP STORIES
EDITOR’S CHOICE English
MOST VIEWED
